Introducción
After removing the back case and battery, the motherboard is easy to remove from the Miix 2.
Qué necesitas
Remove the back cover of the tablet by inserting a nylon or metal spudger in the small hole between the screen and rear cover near the volume button. Slide the tool along the edge of the tablet to release the internal clasps.
Remove the red and black connector cable linking the speakers to the motherboard with tweezers by pulling the connector to the left with a light degree of force.
Locate the LCD cable connector and gently pry it directly up with a spudger.
4 personas más completaron esta guía.
3 comentarios
Do i need to update the BIOS once i have done this?
Do i also need to update the serial number of the machine?
No, you should not have to upflash the BIOS and re-tattoo the machine - Assuming your replacement board has the proper OS entitlements already tattooed onto the UEFI , it should be picked up by the OS (Windows 10, I hope) and automatically re-activated. In fact, I imaged a Miix 2 8 out using a bootable USB drive + Clonezilla, and was able to image it into a new board and have everything re-activate just fine.
