Introducción
The motherboard acts as the central hub of communication between all of the components in your device. If random applications are quitting or if you’re seeing the “blue screen of death” (BSoD), it may be time to replace the motherboard in your computer. This guide will go through the steps on how to replace the motherboard of the Lenovo Legion Y530-15ICH.
Qué necesitas
Use a PZ00 screwdriver bit to remove the eleven screws securing the back cover.
Five 7mm screws
Two 6mm screws
Four 4mm screws
Use a Phillips screwdriver to remove the five 4 mm screws holding the battery in place.
Use a JIS #1 screwdriver to loosen the five spring screws located at the middle of the fan piece.
Remove the plastic covering after the screws have been loosened.
Remove one 4mm screw circled in orange in the second picture with a JIS #1 screwdriver.
Start by disconnecting the ribbon cable that is near the audio driver. It is recommended to use the iFixit Opening Pick to remove the ribbon cable.
4 personas más completaron esta guía.
3 comentarios
Kaylie Klausing
I hope you burn in !&&*
You fckking piece of $@$*.
DON'T FOLLOW THIS.
FCKKKK YOUUUUU
What the hell is wrong with this guy?
