Saltar al contenido principal
Lenovo Legion Y530-15ICH Hard Drive Replacement
Qué necesitas
  1. Lenovo Legion Y530-15ICH Hard Drive Replacement, External screws: paso 1, imagen 1 de 1
    • Shut down the computer and disconnect the power supply.
    • Using a PH1 screwdriver or bit, remove eleven screws securing the back cover.
    • Five 7mm screws
    • Two 6mm screws
    • Four 4mm screws
  2. Lenovo Legion Y530-15ICH Hard Drive Replacement, Rear enclosure: paso 2, imagen 1 de 2 Lenovo Legion Y530-15ICH Hard Drive Replacement, Rear enclosure: paso 2, imagen 2 de 2
    • Carefully pry the back cover off the computer using an opening pick.
    • Start at one of the rear corners of the laptop and work your way around the chassis, gently pulling up on the cover until it detaches.
    • Do not pull hard on the cover or attempt to open without picks, as I did, cracking the side of the rear cover.
  3. Lenovo Legion Y530-15ICH Hard Drive Replacement: paso 3, imagen 1 de 2 Lenovo Legion Y530-15ICH Hard Drive Replacement: paso 3, imagen 2 de 2
    • Remove four screws from the HDD case, mostly releasing it from the laptop.
    • Four 4mm screws
    • You might see a yellow piece of tape here. Peel it off carefully, right to left in this orientation, so that the blue plastic of the ribbon cable beneath is unmoved when it's gone.
  4. Lenovo Legion Y530-15ICH Hard Drive Replacement: paso 4, imagen 1 de 2 Lenovo Legion Y530-15ICH Hard Drive Replacement: paso 4, imagen 2 de 2
    • Use your prying tool or a spudger to flip up the FFC bail, the tiny black clamp shown here.
    • If the cable doesn't move freely after the bail is up, make sure it's pushed all the way back, and lightly tug the cable away from its clamp.
    • Pull only parallel to the board, and only after the bail is up.
  5. Lenovo Legion Y530-15ICH Hard Drive Replacement: paso 5, imagen 1 de 1
    • Once the screws are gone and the ribbon cable is safely disconnected, remove the hard drive with the casing from the rest of the computer.
    • Remove four screws from the casing, releasing the hard drive.
    • Four 3.5mm screws
  6. Lenovo Legion Y530-15ICH Hard Drive Replacement: paso 6, imagen 1 de 1
    • Remove the hard drive from the casing.
  7. Lenovo Legion Y530-15ICH Hard Drive Replacement: paso 7, imagen 1 de 2 Lenovo Legion Y530-15ICH Hard Drive Replacement: paso 7, imagen 2 de 2
    • This piece connects your hard drive to the computer. Remove it carefully, wiggling back and forth. Replace it on your new hard drive.
Conclusión
Once the ribbon cable piece has been attached to the new hard drive, just follow these steps in the reverse order.
Isak
Miembro Desde 08/30/24
249 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 6
Ultimos 30 días: 31
Todo El Tiempo: 344
