Saltar al contenido principal
Lenovo Ideapad 320-15IAP Battery Replacement
Qué necesitas
  1. Lenovo Ideapad 320-15IAP Battery Replacement, Battery: paso 1, imagen 1 de 2 Lenovo Ideapad 320-15IAP Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Using a Phillips #0 screwdriver, unscrew all thirteen 6.5 mm screws from the back case.
  2. Lenovo Ideapad 320-15IAP Battery Replacement: paso 2, imagen 1 de 1
    • Pull the CD drive outwards with an opening tool until it pops out as shown. It is possible you have to apply a substantial amount of force so watch your fingers while doing so.
    • Remove the CD drive.
  3. Lenovo Ideapad 320-15IAP Battery Replacement: paso 3, imagen 1 de 1
    • Lift up the cover using the opening tool on different spots along the side of the laptop.
  4. Lenovo Ideapad 320-15IAP Battery Replacement: paso 4, imagen 1 de 2 Lenovo Ideapad 320-15IAP Battery Replacement: paso 4, imagen 2 de 2
    • Using a Phillips #0 screwdriver to unscrew the four 5.5 mm screws securing the battery.
  5. Lenovo Ideapad 320-15IAP Battery Replacement: paso 5, imagen 1 de 2 Lenovo Ideapad 320-15IAP Battery Replacement: paso 5, imagen 2 de 2
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  6. Lenovo Ideapad 320-15IAP Battery Replacement: paso 6, imagen 1 de 1
    • Remove the battery.
Conclusión
For optimal performance, after completing this guide, calibrate your newly installed battery.
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 6
Ultimos 30 días: 43
Todo El Tiempo: 1,200
