Saltar al contenido principal
Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement
Qué necesitas
  1. Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement, Battery: paso 1, imagen 1 de 1
    • Ensure that your device is completely OFF before performing this procedure.
    • Unscrew the eleven 4 mm Phillips #0 screws on the bottom of the device.
  2. Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: paso 2, imagen 1 de 2 Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: paso 2, imagen 2 de 2
    • Separate the back lid from the laptop using a plastic opening tool.
    • Lift the back lid off of the device.
  3. Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: paso 3, imagen 1 de 2 Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: paso 3, imagen 2 de 2
    • Remove the battery connector from its socket by pulling the cable away from the hinge using your fingers or a plastic opening tool.
    • Do not pull on the socket itself or you risk damaging the motherboard.
    • Remove the two pieces of tape that are holding the battery down.
  4. Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: paso 4, imagen 1 de 1
    • Remove the five 4 mm Phillips screws securing the battery.
  5. Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: paso 5, imagen 1 de 2 Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: paso 5, imagen 2 de 2
    • Lift the battery up and out of the device.
  6. Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement, Wi-Fi Card: paso 6, imagen 1 de 1
    • Locate the Wi-Fi card.
  7. Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: paso 7, imagen 1 de 1
    • Disconnect the two wires that are connected to the Wi-Fi card by gently pulling them up.
  8. Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: paso 8, imagen 1 de 2 Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: paso 8, imagen 2 de 2
    • Unscrew the one 4mm screw keeping the card in place.
  9. Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: paso 9, imagen 1 de 2 Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: paso 9, imagen 2 de 2
    • Gently pull the Wi-Fi card out of place.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 11
Ultimos 30 días: 22
Todo El Tiempo: 1,249
