Saltar al contenido principal
Lenovo IdeaPad Yoga 11S Top Assembly Replacement
Qué necesitas
  1. Lenovo IdeaPad Yoga 11S Top Assembly Replacement, Top Assembly: paso 1, imagen 1 de 3 Lenovo IdeaPad Yoga 11S Top Assembly Replacement, Top Assembly: paso 1, imagen 2 de 3 Lenovo IdeaPad Yoga 11S Top Assembly Replacement, Top Assembly: paso 1, imagen 3 de 3
    • Remember to power off the device before removing any parts.
    • Position the laptop so that the bottom enclosure is facing upward.
    • Use a Phillips #0 Screwdriver to remove the ten 1.9mm screws holding the bottom enclosure in place.
    • Use an opening tool to carefully pry up the rubber pads.
    • Use a Phillips screwdriver to remove the two screws under the rubber pads, which secure the keyboard.
  2. Lenovo IdeaPad Yoga 11S Top Assembly Replacement, Remove Keyboard: paso 2, imagen 1 de 1
    • Flip the laptop over and swing open the display.
    • Lift the edge of the keyboard closest to the trackpad up.
    • Carefully disconnect keyboard ribbon cable from the laptop.
    • Remove the keyboard.
  3. Lenovo IdeaPad Yoga 11S Top Assembly Replacement: paso 3, imagen 1 de 1
    • Remove the two screws securing the midframe.
  4. Lenovo IdeaPad Yoga 11S Top Assembly Replacement: paso 4, imagen 1 de 3 Lenovo IdeaPad Yoga 11S Top Assembly Replacement: paso 4, imagen 2 de 3 Lenovo IdeaPad Yoga 11S Top Assembly Replacement: paso 4, imagen 3 de 3
    • Grab the front edge of the top assembly and lift it up carefully.
    • There are three ribbon cables that attach the top assembly to the motherboard. Lift carefully to avoid damaging them.
    • Gently slide the three ribbon cables out of their slots.
    • Remove the top assembly completely by pulling it off of the device.
Conclusión
2 personas más completaron esta guía.
Landon Epps
Miembro Desde 03/26/15
982 Reputación
5 Guías creadas
Equipo
Baylor, Team 7-11, Williams Spring 2015 Miembro de Baylor, Team 7-11, Williams Spring 2015
BU-WILLIAMS-S15S7G11
Miembros de 3
10 Guías creadas
1Guía Comentario
I am looking into buying one of these but looking at your pictures I can't find the SSD. Is it user upgradeable?
ggr - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 22
Todo El Tiempo: 3,366
