Saltar al contenido principal
Lenovo IdeaPad Y580-2099 Keyboard Replacement
Qué necesitas
  1. Lenovo IdeaPad Y580-2099 Keyboard Replacement, Battery: paso 1, imagen 1 de 1
    • Slide out both locks for the battery, located on the back of the device.
  2. Lenovo IdeaPad Y580-2099 Keyboard Replacement: paso 2, imagen 1 de 2 Lenovo IdeaPad Y580-2099 Keyboard Replacement: paso 2, imagen 2 de 2
    • Remove the battery.
  3. Lenovo IdeaPad Y580-2099 Keyboard Replacement, Keyboard: paso 3, imagen 1 de 2 Lenovo IdeaPad Y580-2099 Keyboard Replacement, Keyboard: paso 3, imagen 2 de 2
    • Unscrew the 2 screws on the bottom of the device.
    • Slide the back panel out.
  4. Lenovo IdeaPad Y580-2099 Keyboard Replacement: paso 4, imagen 1 de 1
    • Unscrew the 3 "keyboard" detected screws.
  5. Lenovo IdeaPad Y580-2099 Keyboard Replacement: paso 5, imagen 1 de 2 Lenovo IdeaPad Y580-2099 Keyboard Replacement: paso 5, imagen 2 de 2
    • Flip the laptop over and open up.
    • Then pry up the whole keyboard using the spudger.
    • Make sure to use a plastic spudger. You could damage the device using anything else.
    • Make sure not to take the frame that goes around the keys off. This part is not removable.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 1,513
