Saltar al contenido principal
Lenovo IdeaPad S210 Touch Back Panel Replacement
Qué necesitas
  1. Lenovo IdeaPad S210 Touch Back Panel Replacement, Battery: paso 1, imagen 1 de 1
    • Ensure your device is unplugged and shut down.
    • Place the laptop down with the cooling vents facing upwards.
  2. Lenovo IdeaPad S210 Touch Back Panel Replacement: paso 2, imagen 1 de 2 Lenovo IdeaPad S210 Touch Back Panel Replacement: paso 2, imagen 2 de 2
    • Use your finger to slide the latch towards the unlocked position (away from the other latch). If done correctly you will see red.
    • Slide the second latch to the unlocked position while gently pulling the battery away from the laptop.
  3. Lenovo IdeaPad S210 Touch Back Panel Replacement, Back Panel: paso 3, imagen 1 de 2 Lenovo IdeaPad S210 Touch Back Panel Replacement, Back Panel: paso 3, imagen 2 de 2
    • Using the #0 Phillips screwdriver, remove the nine 4mm screws on the back panel.
  4. Lenovo IdeaPad S210 Touch Back Panel Replacement: paso 4, imagen 1 de 1
    • Gently pull the two rubber feet closest to battery away from the device. Using a #0 Phillips screwdriver, remove the 5mm screw under each rubber foot.
  5. Lenovo IdeaPad S210 Touch Back Panel Replacement: paso 5, imagen 1 de 3 Lenovo IdeaPad S210 Touch Back Panel Replacement: paso 5, imagen 2 de 3 Lenovo IdeaPad S210 Touch Back Panel Replacement: paso 5, imagen 3 de 3
    • Slowly begin working your plastic opening tool along the panel to undo the latches around the laptop.
Conclusión
Zack Colman
Miembro Desde 07/08/19
906 Reputación
8 Guías creadas
1Guía Comentario
Witam ile zatok część chce pan
Mikolaj Dabrowski - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 20
Todo El Tiempo: 604
