Saltar al contenido principal
Lenovo IdeaPad Flex 4-1470 Wifi Card Replacement
Qué necesitas
  1. Lenovo IdeaPad Flex 4-1470 Wifi Card Replacement, Lower Case: paso 1, imagen 1 de 1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Wifi Card Replacement: paso 2, imagen 1 de 2 Lenovo IdeaPad Flex 4-1470 Wifi Card Replacement: paso 2, imagen 2 de 2
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 Wifi Card Replacement, Wifi Card: paso 3, imagen 1 de 1
    • Remove the foam on the WIFI card.
  4. Lenovo IdeaPad Flex 4-1470 Wifi Card Replacement: paso 4, imagen 1 de 1
    • Remove the wires attached to the WIFI card.
  5. Lenovo IdeaPad Flex 4-1470 Wifi Card Replacement: paso 5, imagen 1 de 1
    • Unscrew the 4mm screw holding wifi card.
Conclusión
Una persona más ha completado esta guía.
Elijah Ellis
Miembro Desde 11/08/18
616 Reputación
5 Guías creadas
Equipo
UMass Dartmouth, Team S5-G2, Gulbrandsen Fall 2018 Miembro de UMass Dartmouth, Team S5-G2, Gulbrandsen Fall 2018
UMASSD-GULBRANDSEN-F18S5G2
Miembros de 3
5 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 1,922
