Saltar al contenido principal
Lenovo IdeaPad Flex 4-1470 Touchpad Replacement
Qué necesitas
  1. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement, Lower Case: paso 1, imagen 1 de 1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement: paso 2, imagen 1 de 2 Lenovo IdeaPad Flex 4-1470 Touchpad Replacement: paso 2, imagen 2 de 2
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement, Battery: paso 3, imagen 1 de 2 Lenovo IdeaPad Flex 4-1470 Touchpad Replacement, Battery: paso 3, imagen 2 de 2
    • Disconnect the battery connector by using a plastic pry tool or your fingers to push the cable right towards the battery.
    • Do not pry or push on the socket itself or you risk damaging the motherboard.
  4. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement: paso 4, imagen 1 de 1
    • Remove the three 4 mm Phillips #0 screws holding the battery in place.
  5. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement: paso 5, imagen 1 de 1
    • Lift the battery up and out of the laptop.
  6. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement, Touchpad: paso 6, imagen 1 de 1
    • Locate the touchpad.
  7. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement: paso 7, imagen 1 de 2 Lenovo IdeaPad Flex 4-1470 Touchpad Replacement: paso 7, imagen 2 de 2
    • Remove the three ribbon cables surrounding the touch pad.
  8. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement: paso 8, imagen 1 de 1
    • Lift the base of the laptop from the screen and gently push the touchpad to remove.
Conclusión
2 personas más completaron esta guía.
Elijah Ellis
Miembro Desde 11/08/18
616 Reputación
5 Guías creadas
Equipo
2 comentarios
do you know where to find this part? i have been looking everywhere haha.
Hanna Tafete - Contestar
Can any body repair lenovo idea pad 1470. Touch screen ...tia
jgonzales - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 1,198
