Saltar al contenido principal
Lenovo IdeaPad Flex 4-1470 Motherboard Replacement
Qué necesitas
  1. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement, Lower Case: paso 1, imagen 1 de 1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: paso 2, imagen 1 de 2 Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: paso 2, imagen 2 de 2
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement, Cooling Fan: paso 3, imagen 1 de 2 Lenovo IdeaPad Flex 4-1470 Motherboard Replacement, Cooling Fan: paso 3, imagen 2 de 2
    • Remove the two 4 mm Phillips #0 screws which mount the fan.
  4. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: paso 4, imagen 1 de 3 Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: paso 4, imagen 2 de 3 Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: paso 4, imagen 3 de 3
    • Using the Precision Tweezers, remove the 2 gray wires around the fan from their clips.
  5. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: paso 5, imagen 1 de 2 Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: paso 5, imagen 2 de 2
    • Use 2 plastic opening tools to remove the fans power wire from the Mother board and remove the fan.
    • Lift the cooling fan out of the laptop.
  6. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement, Wifi Card: paso 6, imagen 1 de 1
    • Remove the foam on the WIFI card.
  7. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: paso 7, imagen 1 de 1
    • Remove the wires attached to the WIFI card.
  8. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: paso 8, imagen 1 de 1
    • Unscrew the 4mm screw holding wifi card.
  9. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement, Motherboard: paso 9, imagen 1 de 1
    • Unscrew the twelve 4mm screws with a #0 Phillips screwdriver.
  10. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: paso 10, imagen 1 de 1
    • Remove the motherboard.
    • The motherboard will be in place when the screw holes line up.
Conclusión
2 personas más completaron esta guía.
Elijah Ellis
Miembro Desde 11/08/18
616 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 1,273
