Saltar al contenido principal
Lenovo G50-80 80E5 Battery Replacement
  1. Lenovo G50-80 80E5 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Place the laptop on a flat surface with the back cover facing up and the hinges facing you.
  2. Lenovo G50-80 80E5 Battery Replacement: paso 2, imagen 1 de 3 Lenovo G50-80 80E5 Battery Replacement: paso 2, imagen 2 de 3 Lenovo G50-80 80E5 Battery Replacement: paso 2, imagen 3 de 3
    • Slide the tab positioned on the right side to the right.
    • You will know this has been done correctly when you can see the red surface beneath the tab.
  3. Lenovo G50-80 80E5 Battery Replacement: paso 3, imagen 1 de 3 Lenovo G50-80 80E5 Battery Replacement: paso 3, imagen 2 de 3 Lenovo G50-80 80E5 Battery Replacement: paso 3, imagen 3 de 3
    • Move the left tab to the left to release the battery.
    • You will hear an audible 'click' and see the battery separate from the rest of the laptop.
  4. Lenovo G50-80 80E5 Battery Replacement: paso 4, imagen 1 de 3 Lenovo G50-80 80E5 Battery Replacement: paso 4, imagen 2 de 3 Lenovo G50-80 80E5 Battery Replacement: paso 4, imagen 3 de 3
    • Hold the battery at the top seam between it and the laptop.
    • Roll the battery towards yourself.
    • Lift the battery out of the laptop.
Conclusión
5 personas más completaron esta guía.
Abigail Hood
Miembro Desde 10/17/17
405 Reputación
2 Guías creadas
Equipo
Un comentario
I purchased a new battery. I think I have not put the new one correctly. It does not align right. The computer is working fine. But it does not charge until I place a couple of books under the battery case, to kind of keep it in place..
Ashish Nelson - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 23
Todo El Tiempo: 4,792
