Saltar al contenido principal
Lenovo Essential G580 Optical Drive Replacement
Qué necesitas
  1. Lenovo Essential G580 Optical Drive Replacement, Optical Drive: paso 1, imagen 1 de 1
    • Locate the removable portion on the bottom of the laptop.
  2. Lenovo Essential G580 Optical Drive Replacement: paso 2, imagen 1 de 1
    • Using a size 00 Phillips Head screwdriver, remove the two M2.5x4 screws connecting the removable plate to the frame of the computer.
  3. Lenovo Essential G580 Optical Drive Replacement: paso 3, imagen 1 de 1
    • Using both hands, slide the plate off of the back of the laptop.
  4. Lenovo Essential G580 Optical Drive Replacement: paso 4, imagen 1 de 1
    • Remove the M2.5x6 screw that fastens the optical drive to the laptop.
  5. Lenovo Essential G580 Optical Drive Replacement: paso 5, imagen 1 de 1
    • Using a spudger, push against the portion of the drive that was fastened. Be sure to push the drive outward as though it was opening. This completely ejects the device and prepares the laptop for a replacement part.
Conclusión
3 personas más completaron esta guía.
Tyler Robbins
Miembro Desde 03/02/17
182 Reputación
1 Guía escrita
Equipo
USF Tampa, Team S13-G3, Cagle Spring 2017 Miembro de USF Tampa, Team S13-G3, Cagle Spring 2017
USFT-CAGLE-S17S13G3
4 Miembros
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 2,131
