Saltar al contenido principal
Lenovo 500e Chromebook 2nd Gen Battery Replacement
Qué necesitas
  1. Lenovo 500e Chromebook 2nd Gen Battery Replacement, Back Panel: paso 1, imagen 1 de 1
    • Remove nine 6 mm screws from the bottom cover of the laptop using a Phillips #0 screwdriver.
  2. Lenovo 500e Chromebook 2nd Gen Battery Replacement: paso 2, imagen 1 de 2 Lenovo 500e Chromebook 2nd Gen Battery Replacement: paso 2, imagen 2 de 2
    • Remove stylus from the lower left corner of the back panel.
  3. Lenovo 500e Chromebook 2nd Gen Battery Replacement: paso 3, imagen 1 de 2 Lenovo 500e Chromebook 2nd Gen Battery Replacement: paso 3, imagen 2 de 2
    • Go along the edge of the back panel with an iFixit opening tool until it pops loose.
    • Remove the back panel from the laptop.
  4. Lenovo 500e Chromebook 2nd Gen Battery Replacement, Battery: paso 4, imagen 1 de 1
    • Remove the four 4 mm Phillips #00 screws holding the battery in.
  5. Lenovo 500e Chromebook 2nd Gen Battery Replacement: paso 5, imagen 1 de 2 Lenovo 500e Chromebook 2nd Gen Battery Replacement: paso 5, imagen 2 de 2
    • Use the iFixit opening tool to unplug the battery from the motherboard.
    • Potential for device damage: Make sure to be gentle while removing the wire.
  6. Lenovo 500e Chromebook 2nd Gen Battery Replacement: paso 6, imagen 1 de 1
    • Remove the battery from the laptop.
Conclusión
3 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 26
Todo El Tiempo: 514
