Saltar al contenido principal
Lenovo 100s Chromebook-11IBY Battery Replacement
Qué necesitas
  1. Lenovo 100s Chromebook-11IBY Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Ensure your device is turned off and unplugged.
  2. Lenovo 100s Chromebook-11IBY Battery Replacement: paso 2, imagen 1 de 1
    • Use a Phillips #0 screwdriver to remove the nine 6mm screws from the larger back plate.
  3. Lenovo 100s Chromebook-11IBY Battery Replacement: paso 3, imagen 1 de 2 Lenovo 100s Chromebook-11IBY Battery Replacement: paso 3, imagen 2 de 2
    • Turn your laptop back over, open it, and use the plastic opening tool on the recessed notch to gently pry each side and lift the keyboard plate up.
    • Be careful not to pull keyboard plate out immediately because cables are attached.
  4. Lenovo 100s Chromebook-11IBY Battery Replacement: paso 4, imagen 1 de 2 Lenovo 100s Chromebook-11IBY Battery Replacement: paso 4, imagen 2 de 2
    • Unlock the keyboard ZIF connector to release the keyboard flex cable.
    • To unlock a ZIF connector, use an opening tool or your fingernail to flip up the small, hinged locking flap.
    • Unlock the touchpad ZIF connector to release the touchpad flex cable.
    • Carefully pull both flex cables out of the ZIF connectors.
    • Remove the keyboard plate up and place it to the side.
  5. Lenovo 100s Chromebook-11IBY Battery Replacement: paso 5, imagen 1 de 1
    • Unplug the battery cable by pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  6. Lenovo 100s Chromebook-11IBY Battery Replacement: paso 6, imagen 1 de 1
    • Use the Phillips #0 screwdriver to remove the three 6mm screws from the battery.
  7. Lenovo 100s Chromebook-11IBY Battery Replacement: paso 7, imagen 1 de 1
    • Remove the battery.
Conclusión
For optimal performance, after completing this guide, calibrate your newly installed battery.
2 personas más completaron esta guía.
Milton Perez
Miembro Desde 03/09/17
630 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S7-G2, Cagle Spring 2017 Miembro de USF Tampa, Team S7-G2, Cagle Spring 2017
USFT-CAGLE-S17S7G2
1 Miembro
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 7
Todo El Tiempo: 2,435
