Saltar al contenido principal
LeapFrog LeapPad Ultra XDi Home Button Replacement
Qué necesitas
  1. LeapFrog LeapPad Ultra XDi Home Button Replacement, Battery: paso 1, imagen 1 de 2 LeapFrog LeapPad Ultra XDi Home Button Replacement, Battery: paso 1, imagen 2 de 2
    • Orient the tablet so it’s laying screen down and the barcode sticker is facing up.
    • Remove the barcode sticker to expose the two screws.
  2. LeapFrog LeapPad Ultra XDi Home Button Replacement: paso 2, imagen 1 de 2 LeapFrog LeapPad Ultra XDi Home Button Replacement: paso 2, imagen 2 de 2
    • Remove the two 5.0mm Phillips #0 screws.
  3. LeapFrog LeapPad Ultra XDi Home Button Replacement: paso 3, imagen 1 de 3 LeapFrog LeapPad Ultra XDi Home Button Replacement: paso 3, imagen 2 de 3 LeapFrog LeapPad Ultra XDi Home Button Replacement: paso 3, imagen 3 de 3
    • Using the iFixit opening tool, pry off the purple and white child-proof casing to expose the twelve screws.
  4. LeapFrog LeapPad Ultra XDi Home Button Replacement: paso 4, imagen 1 de 2 LeapFrog LeapPad Ultra XDi Home Button Replacement: paso 4, imagen 2 de 2
    • Remove all twelve 7mm Phillips #1 screws located along the edges of the device.
  5. LeapFrog LeapPad Ultra XDi Home Button Replacement: paso 5, imagen 1 de 2 LeapFrog LeapPad Ultra XDi Home Button Replacement: paso 5, imagen 2 de 2
    • Remove the purple case, exposing the motherboard and battery.
  6. LeapFrog LeapPad Ultra XDi Home Button Replacement: paso 6, imagen 1 de 3 LeapFrog LeapPad Ultra XDi Home Button Replacement: paso 6, imagen 2 de 3 LeapFrog LeapPad Ultra XDi Home Button Replacement: paso 6, imagen 3 de 3
    • Use the Spudger to remove the glued down battery.
    • Using your fingers, grab the battery wires and carefully unplug them from the motherboard.
    • Replace the battery with a new one.
  7. LeapFrog LeapPad Ultra XDi Home Button Replacement, Home Button: paso 7, imagen 1 de 3 LeapFrog LeapPad Ultra XDi Home Button Replacement, Home Button: paso 7, imagen 2 de 3 LeapFrog LeapPad Ultra XDi Home Button Replacement, Home Button: paso 7, imagen 3 de 3
    • Locate the three ribbon cables on top of the motherboard.
    • Flip up the locking clip on the ribbon cable connector to release the cable.
    • Disconnect the cables from their connectors.
  8. LeapFrog LeapPad Ultra XDi Home Button Replacement: paso 8, imagen 1 de 3 LeapFrog LeapPad Ultra XDi Home Button Replacement: paso 8, imagen 2 de 3 LeapFrog LeapPad Ultra XDi Home Button Replacement: paso 8, imagen 3 de 3
    • Unscrew the four 5mm Phillips #1 screws.
    • Unscrew the two 5mm Phillips #1 screws.
    • Lift the home button circuit board up. Replace the home button circuit board.
    • The entire home button circuit board must be replaced.
    • Do not dispose of rubber padding on home button circuit board.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 255
