Saltar al contenido principal
Lasko CD08200 Disassembly
Qué necesitas
  1. Lasko CD08200 Disassembly, Lasko CD08200 Disassembly: paso 1, imagen 1 de 2 Lasko CD08200 Disassembly, Lasko CD08200 Disassembly: paso 1, imagen 2 de 2
    • Turn over the device and place it on its head.
    • Remove the four 14mm screws holding the bottom using a TR15 screwdriver.
  2. Lasko CD08200 Disassembly: paso 2, imagen 1 de 1
    • Remove both 14mm screws from the power cord casing using a Phillips #2 screwdriver.
    • Remove the power cord casing from the device case.
  3. Lasko CD08200 Disassembly: paso 3, imagen 1 de 3 Lasko CD08200 Disassembly: paso 3, imagen 2 de 3 Lasko CD08200 Disassembly: paso 3, imagen 3 de 3
    • Cut the sticker on the right side of the device using a Jimmy.
    • Unscrew the four 14mm screws with a Phillips #2 bit on the back of the device.
    • If your screwdriver cannot reach the screw, you can use the metal spudger.
    • Remove the back casing from the device.
  4. Lasko CD08200 Disassembly: paso 4, imagen 1 de 3 Lasko CD08200 Disassembly: paso 4, imagen 2 de 3 Lasko CD08200 Disassembly: paso 4, imagen 3 de 3
    • Remove the four 14mm screws housing the fan using the Phillips #2 screwdriver.
    • Remove the top of the fan housing with the fan attached and place it on the table.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 293
