Introducción
The panel is a curved component that is part of the outer covering of a device. A faulty panel can cause your Lasko CD08200 heater to be exposed to outside sources such as water which can lead to unfortunate incidents. In some cases, your heater may not work at all if it has a faulty panel.
Before using this guide, make sure to review the troubleshooting page to be sure if replacing the control panel is the correct action to fix your device.
Qué necesitas
Turn over the device and place it on its head.
Remove the four 14mm screws holding the bottom using a TR15 screwdriver.
Unscrew the four rings using the Phillips #2.
Gently remove the fan base from the device.
Una persona más ha completado esta guía.
