Saltar al contenido principal
LaCie Rugged USB-C Hard Drive Replacement
Qué necesitas
  1. LaCie Rugged USB-C Hard Drive Replacement, Overview: paso 1, imagen 1 de 3 LaCie Rugged USB-C Hard Drive Replacement, Overview: paso 1, imagen 2 de 3 LaCie Rugged USB-C Hard Drive Replacement, Overview: paso 1, imagen 3 de 3
    • This guide contains steps for the LaCie Rugged USB-C. There is no guarantee that the steps will be the same for different models.
  2. LaCie Rugged USB-C Hard Drive Replacement, Case Removal: paso 2, imagen 1 de 2 LaCie Rugged USB-C Hard Drive Replacement, Case Removal: paso 2, imagen 2 de 2
    • Remove the rubber case around the drive. You can just stretch it off.
  3. LaCie Rugged USB-C Hard Drive Replacement, Case Screws: paso 3, imagen 1 de 2 LaCie Rugged USB-C Hard Drive Replacement, Case Screws: paso 3, imagen 2 de 2
    • Remove these 4x Torx T8 screws
  4. LaCie Rugged USB-C Hard Drive Replacement, Case Removal: paso 4, imagen 1 de 2 LaCie Rugged USB-C Hard Drive Replacement, Case Removal: paso 4, imagen 2 de 2
    • Push on one side of the drive, where the white plastic is. Which side does not matter.
  5. LaCie Rugged USB-C Hard Drive Replacement, Preparing for Drive Removal: paso 5, imagen 1 de 2 LaCie Rugged USB-C Hard Drive Replacement, Preparing for Drive Removal: paso 5, imagen 2 de 2
    • Push GENTLY on the back side of the hard drive.
    • DO NOT push more than is necessary to get the drive above the white plastic, as shown in the second picture.
  6. LaCie Rugged USB-C Hard Drive Replacement, Drive Removal: paso 6, imagen 1 de 1
    • Pull the drive gently out of the SATA connector.
Conclusión
6 personas más completaron esta guía.
9021007
Miembro Desde 07/13/18
4,599 Reputación
25 Guías creadas
4 comentarios
Thanks for confirming the T8 Torx security bit - I had to buy a set!
Andy Gibbons - Contestar
Andy, how are you. ?
Am facing the same issue, did fixed yours ?
Dion Diogo Mar -
Hello, I have this same drive. My hard drive is fine, the internal case that has the SATA to USB C connector isn’t working. Is there a replacement for the adapter/inner case & the adapter?
James Causey - Contestar
I have no idea of replacement of the LaCie internal case
But any generic USB C To SATA Adapter can be used - and very cheap on amazon too
Like in this link for example
Eoin -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 31
Ultimos 30 días: 109
Todo El Tiempo: 5,714
