Saltar al contenido principal
LaCie Rugged USB-C Circuit Board Replacement
Qué necesitas
  1. LaCie Rugged USB-C Circuit Board Replacement, Overview: paso 1, imagen 1 de 3 LaCie Rugged USB-C Circuit Board Replacement, Overview: paso 1, imagen 2 de 3 LaCie Rugged USB-C Circuit Board Replacement, Overview: paso 1, imagen 3 de 3
    • This guide contains steps for the LaCie Rugged USB-C. There is no guarantee that the steps will be the same for different models.
  2. LaCie Rugged USB-C Circuit Board Replacement, Case Removal: paso 2, imagen 1 de 2 LaCie Rugged USB-C Circuit Board Replacement, Case Removal: paso 2, imagen 2 de 2
    • Remove the rubber case around the drive. You can just stretch it off.
  3. LaCie Rugged USB-C Circuit Board Replacement, Case Screws: paso 3, imagen 1 de 2 LaCie Rugged USB-C Circuit Board Replacement, Case Screws: paso 3, imagen 2 de 2
    • Remove these 4x Torx T8 screws
  4. LaCie Rugged USB-C Circuit Board Replacement, Case Removal: paso 4, imagen 1 de 2 LaCie Rugged USB-C Circuit Board Replacement, Case Removal: paso 4, imagen 2 de 2
    • Push on one side of the drive, where the white plastic is. Which side does not matter.
  5. LaCie Rugged USB-C Circuit Board Replacement, Preparing for Drive Removal: paso 5, imagen 1 de 2 LaCie Rugged USB-C Circuit Board Replacement, Preparing for Drive Removal: paso 5, imagen 2 de 2
    • Push GENTLY on the back side of the hard drive.
    • DO NOT push more than is necessary to get the drive above the white plastic, as shown in the second picture.
  6. LaCie Rugged USB-C Circuit Board Replacement, Drive Removal: paso 6, imagen 1 de 1
    • Pull the drive gently out of the SATA connector.
  7. LaCie Rugged USB-C Circuit Board Replacement, Screw Removal: paso 7, imagen 1 de 1
    • Remove this Phillips 00 screw from the board.
  8. LaCie Rugged USB-C Circuit Board Replacement, Board Removal: paso 8, imagen 1 de 1
    • Slide the board out, making sure to keep any foam pieces intact.
    • Do not let any foam pieces get damaged. They are important.
Conclusión
5 personas más completaron esta guía.
9021007
Miembro Desde 07/13/18
4,599 Reputación
25 Guías creadas
4 comentarios
Where can i get a new board? thank you
Bar Avraham - Contestar
Yes, where can we find a new board?
Vassilis Trigkas - Contestar
Right, where can the part be purchased?????
James Causey - Contestar
anybody find where you can get a replacement
Cyle Hawkins - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 11
Ultimos 30 días: 35
Todo El Tiempo: 1,945
