Saltar al contenido principal
LG V10 Loudspeaker Replacement
Qué necesitas
  1. LG V10 Loudspeaker Replacement, Battery: paso 1, imagen 1 de 1
    • Wedge the flat end of the plastic spudger, or the tip of your finger, in between the back cover and the LG V10’s charging port.
    • If using a spudger, it should not be in the charging port, but between the metal lining of the charging port and the back cover.
    • Carefully lift up on the spudger or with your finger so that the back cover pops up. The rest of the back cover should easily come off by sliding a finger or spudger under the back cover and around the sides.
  2. LG V10 Loudspeaker Replacement: paso 2, imagen 1 de 2 LG V10 Loudspeaker Replacement: paso 2, imagen 2 de 2
    • There’s an impression next to the battery for the user to use their finger to pry the battery out; pry the battery out using your finger or the flat end of the spudger.
  3. LG V10 Loudspeaker Replacement, Loudspeaker: paso 3, imagen 1 de 2 LG V10 Loudspeaker Replacement, Loudspeaker: paso 3, imagen 2 de 2
    • Using a screwdriver with a J000 Phillips bit, remove the ten 3.175 mm screws.
    • Using a plastic opening tool, pry part of the panel up starting from the sides of the battery slot.
  4. LG V10 Loudspeaker Replacement: paso 4, imagen 1 de 2 LG V10 Loudspeaker Replacement: paso 4, imagen 2 de 2
    • Carefully but firmly pull on the loudspeaker component to release it from the plastic bits holding it in place.
Conclusión
After replacing the loudspeaker, follow these instructions in reverse order to reassemble the LG V10.
Joseph
Miembro Desde 09/25/17
963 Reputación
4 Guías creadas
Equipo
USF Tampa, Team S16-G3, Eyestone Fall 2017 Miembro de USF Tampa, Team S16-G3, Eyestone Fall 2017
USFT-EYESTONE-F17S16G3
Miembros de 2
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 6
Todo El Tiempo: 476
