Saltar al contenido principal
LG Refrigerator Upper Ice Maker Assembly Replacement
Qué necesitas
  1. LG Refrigerator Upper Ice Maker Assembly Replacement, Unplug your refrigerator: paso 1, imagen 1 de 1
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. LG Refrigerator Upper Ice Maker Assembly Replacement, Open the doors: paso 2, imagen 1 de 3 LG Refrigerator Upper Ice Maker Assembly Replacement, Open the doors: paso 2, imagen 2 de 3 LG Refrigerator Upper Ice Maker Assembly Replacement, Open the doors: paso 2, imagen 3 de 3
    • Open both refrigerator doors fully.
  3. LG Refrigerator Upper Ice Maker Assembly Replacement, Remove the ice maker assembly screws: paso 3, imagen 1 de 2 LG Refrigerator Upper Ice Maker Assembly Replacement, Remove the ice maker assembly screws: paso 3, imagen 2 de 2
    • Use a #2 Philips driver to remove the screws that secure the ice maker assembly to the refrigerator door.
  4. LG Refrigerator Upper Ice Maker Assembly Replacement, Reposition the ice maker assembly: paso 4, imagen 1 de 3 LG Refrigerator Upper Ice Maker Assembly Replacement, Reposition the ice maker assembly: paso 4, imagen 2 de 3 LG Refrigerator Upper Ice Maker Assembly Replacement, Reposition the ice maker assembly: paso 4, imagen 3 de 3
    • Use a spudger to lift the bottom edge of the ice maker assembly. This action will release the assembly from the refrigerator door.
    • Pull the bottom edge of the ice maker assembly toward you to free it from the door.
  5. LG Refrigerator Upper Ice Maker Assembly Replacement: paso 5, imagen 1 de 3 LG Refrigerator Upper Ice Maker Assembly Replacement: paso 5, imagen 2 de 3 LG Refrigerator Upper Ice Maker Assembly Replacement: paso 5, imagen 3 de 3
    • Lower the ice maker assembly until you can access the connector located at the top of the assembly.
    • Squeeze the connector at the top of the ice maker assembly to release it.
    • Pull the connector straight down to disconnect it.
  6. LG Refrigerator Upper Ice Maker Assembly Replacement, Remove the ice maker assembly: paso 6, imagen 1 de 1
    • Remove the ice maker assembly.
Conclusión
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Bill Gilbert
Miembro Desde 06/30/22
30,695 Reputación
213 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
141 Miembros
17,869 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 14
Ultimos 30 días: 39
Todo El Tiempo: 194
