Saltar al contenido principal
LG Refrigerator Freezer Ice Maker Replacement
Qué necesitas
  1. LG Refrigerator Freezer Ice Maker Replacement, Unplug your refrigerator: paso 1, imagen 1 de 1
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. LG Refrigerator Freezer Ice Maker Replacement, Open the freezer door: paso 2, imagen 1 de 2 LG Refrigerator Freezer Ice Maker Replacement, Open the freezer door: paso 2, imagen 2 de 2
    • Pull open the freezer door fully.
  3. LG Refrigerator Freezer Ice Maker Replacement, Remove the drawer and bin: paso 3, imagen 1 de 3 LG Refrigerator Freezer Ice Maker Replacement, Remove the drawer and bin: paso 3, imagen 2 de 3 LG Refrigerator Freezer Ice Maker Replacement, Remove the drawer and bin: paso 3, imagen 3 de 3
    • Lift and remove the upper pull-out drawer.
    • Lift and remove the main drawer bin.
  4. LG Refrigerator Freezer Ice Maker Replacement, Remove the drawer rail covers: paso 4, imagen 1 de 3 LG Refrigerator Freezer Ice Maker Replacement, Remove the drawer rail covers: paso 4, imagen 2 de 3 LG Refrigerator Freezer Ice Maker Replacement, Remove the drawer rail covers: paso 4, imagen 3 de 3
    • Use your finger or a flat-blade screwdriver to depress the two locking tabs on the right drawer rail cover.
    • Lift the cover off of the rail and remove it.
    • Repeat this procedure for the left drawer rail cover.
  5. LG Refrigerator Freezer Ice Maker Replacement, Reassembly notes: paso 5, imagen 1 de 2 LG Refrigerator Freezer Ice Maker Replacement, Reassembly notes: paso 5, imagen 2 de 2
    • The drawer rail covers can be tricky to reinstall. Follow these steps to reinstall them:
    • Hold the drawer rail cover flush against the side of the drawer rail.
    • You should feel the locking tabs protruding.
    • Push the rail cover straight downward to install. It should click into place.
  6. LG Refrigerator Freezer Ice Maker Replacement, Remove the drawer: paso 6, imagen 1 de 2 LG Refrigerator Freezer Ice Maker Replacement, Remove the drawer: paso 6, imagen 2 de 2
    • Use a Phillips screwdriver to remove the screw securing the drawer to each of the drawer slides.
  7. LG Refrigerator Freezer Ice Maker Replacement: paso 7, imagen 1 de 3 LG Refrigerator Freezer Ice Maker Replacement: paso 7, imagen 2 de 3 LG Refrigerator Freezer Ice Maker Replacement: paso 7, imagen 3 de 3
    • Lift the front of the drawer up.
    • Pull the drawer toward you to release the drawer from the drawer slides.
    • Remove the freezer drawer.
  8. LG Refrigerator Freezer Ice Maker Replacement, Release the ice maker: paso 8, imagen 1 de 1
    • Use a Phillips screwdriver to remove the screws securing the ice maker to the top of the freezer compartment.
  9. LG Refrigerator Freezer Ice Maker Replacement: paso 9, imagen 1 de 3 LG Refrigerator Freezer Ice Maker Replacement: paso 9, imagen 2 de 3 LG Refrigerator Freezer Ice Maker Replacement: paso 9, imagen 3 de 3
    • Insert a flat-blade screwdriver into the slot located on the right edge of the ice maker.
    • Pry outward with the screwdriver to release the locking tab securing the ice maker to the fridge.
    • When the tab releases, pull the right front corner of the ice maker down.
  10. LG Refrigerator Freezer Ice Maker Replacement: paso 10, imagen 1 de 1
    • Repeat the previous operation on the left side of the ice maker to release it.
  11. LG Refrigerator Freezer Ice Maker Replacement: paso 11, imagen 1 de 3 LG Refrigerator Freezer Ice Maker Replacement: paso 11, imagen 2 de 3 LG Refrigerator Freezer Ice Maker Replacement: paso 11, imagen 3 de 3
    • Grasp the front edge of the ice maker and pull it towards you.
    • Lower the ice maker.
  12. LG Refrigerator Freezer Ice Maker Replacement, Disconnect and remove the ice maker: paso 12, imagen 1 de 3 LG Refrigerator Freezer Ice Maker Replacement, Disconnect and remove the ice maker: paso 12, imagen 2 de 3 LG Refrigerator Freezer Ice Maker Replacement, Disconnect and remove the ice maker: paso 12, imagen 3 de 3
    • Squeeze the ice maker connector to release it and pull it straight out to disconnect it.
    • Remove the ice maker.
Conclusión
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Bill Gilbert
Miembro Desde 06/30/22
30,695 Reputación
213 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
141 Miembros
17,873 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 10
Ultimos 7 días: 58
Ultimos 30 días: 211
Todo El Tiempo: 758
