Saltar al contenido principal
LG Refrigerator Compressor Run Capacitor Replacement
Qué necesitas
  1. LG Refrigerator Compressor Run Capacitor Replacement, Unplug your refrigerator: paso 1, imagen 1 de 1
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. LG Refrigerator Compressor Run Capacitor Replacement, Unfasten the control board cover: paso 2, imagen 1 de 1
    • Use a Phillips screwdriver to remove the screws securing the control board cover.
  3. LG Refrigerator Compressor Run Capacitor Replacement, Remove the control board cover: paso 3, imagen 1 de 3 LG Refrigerator Compressor Run Capacitor Replacement, Remove the control board cover: paso 3, imagen 2 de 3 LG Refrigerator Compressor Run Capacitor Replacement, Remove the control board cover: paso 3, imagen 3 de 3
    • Tilt the top edge of the cover toward you and lift it off.
  4. LG Refrigerator Compressor Run Capacitor Replacement, Unclip the capacitor: paso 4, imagen 1 de 3 LG Refrigerator Compressor Run Capacitor Replacement, Unclip the capacitor: paso 4, imagen 2 de 3 LG Refrigerator Compressor Run Capacitor Replacement, Unclip the capacitor: paso 4, imagen 3 de 3
    • Pull the left edge of the capacitor toward you to unclip it.
    • Handle the capacitor carefully as it may still be charged, and can give a dangerous and painful electrical shock. Avoid touching the terminals with your fingers or hands.
    • For information on capacitor safety, click here.
  5. LG Refrigerator Compressor Run Capacitor Replacement, Disconnect the capacitor: paso 5, imagen 1 de 3 LG Refrigerator Compressor Run Capacitor Replacement, Disconnect the capacitor: paso 5, imagen 2 de 3 LG Refrigerator Compressor Run Capacitor Replacement, Disconnect the capacitor: paso 5, imagen 3 de 3
    • Pull the connector straight off the capacitor to disconnect it.
    • Remove the capacitor.
Conclusión
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Bill Gilbert
Miembro Desde 06/30/22
30,695 Reputación
213 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
141 Miembros
17,869 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 26
Ultimos 30 días: 109
Todo El Tiempo: 492
