Saltar al contenido principal
LG Phoenix 2 Power and volume buttons Replacement
Qué necesitas
  1. LG Phoenix 2 Power and volume buttons Replacement, Battery: paso 1, imagen 1 de 3 LG Phoenix 2 Power and volume buttons Replacement, Battery: paso 1, imagen 2 de 3 LG Phoenix 2 Power and volume buttons Replacement, Battery: paso 1, imagen 3 de 3
    • Place a fingernail in the notch at the bottom edge of the phone.
    • Pull on the back cover with one hand while keeping the rest of the phone steady, and run your fingernail along the edge.
  2. LG Phoenix 2 Power and volume buttons Replacement: paso 2, imagen 1 de 3 LG Phoenix 2 Power and volume buttons Replacement: paso 2, imagen 2 de 3 LG Phoenix 2 Power and volume buttons Replacement: paso 2, imagen 3 de 3
    • Place a fingernail in the notch at the bottom edge of the battery.
    • Pull the battery out.
  3. LG Phoenix 2 Power and volume buttons Replacement, Power and volume buttons: paso 3, imagen 1 de 2 LG Phoenix 2 Power and volume buttons Replacement, Power and volume buttons: paso 3, imagen 2 de 2
    • Locate the SIM card in the top right corner on the back of the phone.
    • Remove the SIM card by pushing it with your thumb from left to right.
  4. LG Phoenix 2 Power and volume buttons Replacement: paso 4, imagen 1 de 3 LG Phoenix 2 Power and volume buttons Replacement: paso 4, imagen 2 de 3 LG Phoenix 2 Power and volume buttons Replacement: paso 4, imagen 3 de 3
    • Remove all 9 screws on the back by using a Phillips head #J00 screwdriver.
    • To remove the screws rotate them counterclockwise.
  5. LG Phoenix 2 Power and volume buttons Replacement: paso 5, imagen 1 de 3 LG Phoenix 2 Power and volume buttons Replacement: paso 5, imagen 2 de 3 LG Phoenix 2 Power and volume buttons Replacement: paso 5, imagen 3 de 3
    • Insert a plastic opening tool in the split at the bottom of the phone (between the bottom shield and the rest of the phone).
    • Pry the bottom shield to separate it from the phone.
    • Once it is loose you should be able to remove it with your hand.
  6. LG Phoenix 2 Power and volume buttons Replacement: paso 6, imagen 1 de 3 LG Phoenix 2 Power and volume buttons Replacement: paso 6, imagen 2 de 3 LG Phoenix 2 Power and volume buttons Replacement: paso 6, imagen 3 de 3
    • Insert the flat end of the Spudger between the screen and the chromed frame.
    • Once inserted, run the Spudger along the frame to separate the front part of the phone from the back shield.
  7. LG Phoenix 2 Power and volume buttons Replacement: paso 7, imagen 1 de 3 LG Phoenix 2 Power and volume buttons Replacement: paso 7, imagen 2 de 3 LG Phoenix 2 Power and volume buttons Replacement: paso 7, imagen 3 de 3
    • The buttons are attached with adhesive to both sides of the back shield. To separate the orange cables insert a metallic Spudger underneath and gently pull up.
    • Once the orange part is loose move to the next step.
  8. LG Phoenix 2 Power and volume buttons Replacement: paso 8, imagen 1 de 3 LG Phoenix 2 Power and volume buttons Replacement: paso 8, imagen 2 de 3 LG Phoenix 2 Power and volume buttons Replacement: paso 8, imagen 3 de 3
    • Remove the buttons frame on the back side the shield, by inserting a plastic opening tool underneath the frame.
  9. LG Phoenix 2 Power and volume buttons Replacement: paso 9, imagen 1 de 3 LG Phoenix 2 Power and volume buttons Replacement: paso 9, imagen 2 de 3 LG Phoenix 2 Power and volume buttons Replacement: paso 9, imagen 3 de 3
    • The buttons are attached with adhesive. To separate them from the shield insert a metallic Spudger underneath and gently pull up.
    • Once the part is loose you should be able to pass the backside orange cables through the hole.
Conclusión
Esteban Ruibal
Miembro Desde 02/14/18
702 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S2-G2, Eyestone Spring 2018 Miembro de USF Tampa, Team S2-G2, Eyestone Spring 2018
USFT-EYESTONE-S18S2G2
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 12
Todo El Tiempo: 461
