Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Inglés
Español
Traduciendo paso 7
Paso 7
The buttons are attached with adhesive. To separate them from the shield insert a metallic Spudger underneath and gently pull up. Once the part is loose you should be able to pass the backside orange cables through the  hole. Once the part is loose you should be able to pass the backside orange cables through the  hole.
  • The buttons are attached with adhesive. To separate them from the shield insert a metallic Spudger underneath and gently pull up.
  • Once the part is loose you should be able to pass the backside orange cables through the hole.
Insertar traducción aquí
