Saltar al contenido principal
LG K30 Battery Replacement
Qué necesitas
  1. LG K30 Battery Replacement, Battery: paso 1, imagen 1 de 2 LG K30 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Before disassembling your LG K30, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your Phone before beginning disassembly.
    • Use the 'Jimmy' and 'Metal Spudger' to slowly pry open the outsides of the back case.
  2. LG K30 Battery Replacement: paso 2, imagen 1 de 1
    • Remove the thirteen 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
  3. LG K30 Battery Replacement: paso 3, imagen 1 de 1
    • Use a metal spudger or plastic opening tool to pry open the outer cover.
  4. LG K30 Battery Replacement: paso 4, imagen 1 de 1
    • Use the flat end of a spudger to detach the battery connector from the logic board.
  5. LG K30 Battery Replacement: paso 5, imagen 1 de 2 LG K30 Battery Replacement: paso 5, imagen 2 de 2
    • Use a spudger to pry the battery from the phone.
    • There may be an adhesive on the back of the battery and the phone. Pry the battery gently to prevent puncture or damage.
    • Do not bend or puncture the battery.
Conclusión
11 personas más completaron esta guía.
Un comentario
There's no description of removing the display or supporting it. Why is an LG K30 screen with frame required?
P Schmied - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 39
Todo El Tiempo: 12,961
