Saltar al contenido principal
LG K20 PLUS Rear-Facing Camera Replacement
Qué necesitas
  1. LG K20 PLUS Rear-Facing Camera Replacement, Remove the back cover and battery: paso 1, imagen 1 de 2 LG K20 PLUS Rear-Facing Camera Replacement, Remove the back cover and battery: paso 1, imagen 2 de 2
    • Remove the back cover by inserting a fingernail or opening pick here and disengaging the plastic clips.
    • Lift battery up here
  2. LG K20 PLUS Rear-Facing Camera Replacement, Midframe: paso 2, imagen 1 de 1
    • Remove 11 Philips screws.
  3. LG K20 PLUS Rear-Facing Camera Replacement: paso 3, imagen 1 de 2 LG K20 PLUS Rear-Facing Camera Replacement: paso 3, imagen 2 de 2
    • Use fingernails or insert an opening pick into the gap between the digitizer and the midframe and pull the midframe outwards to disengage the plastic clips.
    • Carefully disengage the clips on the bottom as the headphone jack goes through the midframe.
    • Once all the clips have been disengaged, move the midframe outwards and downwards to disengage it from the headphone jack.
  4. LG K20 PLUS Rear-Facing Camera Replacement, Rear-Facing Camera: paso 4, imagen 1 de 1
    Herramienta utilizada en este paso:
    Halberd Spudger
    $2.99
    • Use a Halberd spudger or an opening pick to disconnect the front camera flex from its connector on the motherboard.
Conclusión
Patrick
Miembro Desde 05/14/14
6,586 Reputación
21 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 367
