Saltar al contenido principal
LG K20 PLUS Motherboard Removal
Qué necesitas
  1. LG K20 PLUS Motherboard Removal, Remove the back cover and battery: paso 1, imagen 1 de 2 LG K20 PLUS Motherboard Removal, Remove the back cover and battery: paso 1, imagen 2 de 2
    • Remove the back cover by inserting a fingernail or opening pick here and disengaging the plastic clips.
    • Lift battery up here
  2. LG K20 PLUS Motherboard Removal, Midframe: paso 2, imagen 1 de 1
    • Remove 11 Philips screws.
  3. LG K20 PLUS Motherboard Removal: paso 3, imagen 1 de 2 LG K20 PLUS Motherboard Removal: paso 3, imagen 2 de 2
    • Use fingernails or insert an opening pick into the gap between the digitizer and the midframe and pull the midframe outwards to disengage the plastic clips.
    • Carefully disengage the clips on the bottom as the headphone jack goes through the midframe.
    • Once all the clips have been disengaged, move the midframe outwards and downwards to disengage it from the headphone jack.
  4. LG K20 PLUS Motherboard Removal, Rear-Facing Camera: paso 4, imagen 1 de 1
    Herramienta utilizada en este paso:
    Halberd Spudger
    $2.99
    • Use a Halberd spudger or an opening pick to disconnect the front camera flex from its connector on the motherboard.
  5. LG K20 PLUS Motherboard Removal, Motherboard Removal: paso 5, imagen 1 de 1
    • Using the tip of a Halberd spudger or an opening pick, disconnect the display flex cable from its socket on the motherboard.
    • Starting from the bottom, insert an opening pick between the motherboard and frame and lever apart.
    • Be careful not to break the long section of the motherboard.
    • The top part of the motherboard is lightly adhered to the frame.
    • After the motherboard is removed, compare the original and replacement part. Some components may already be installed on the replacement display assembly.
Conclusión
3 personas más completaron esta guía.
Patrick
Miembro Desde 05/14/14
6,613 Reputación
21 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 804
