Saltar al contenido principal
LG G8 ThinQ Front Cameras Replacement
Qué necesitas
  1. LG G8 ThinQ Front Cameras Replacement, SIM Card Tray: paso 1, imagen 1 de 3 LG G8 ThinQ Front Cameras Replacement, SIM Card Tray: paso 1, imagen 2 de 3 LG G8 ThinQ Front Cameras Replacement, SIM Card Tray: paso 1, imagen 3 de 3
    • Unplug and power off your phone before you begin.
    • Insert the SIM card eject tool into the pinhole in the lower right side of the phone.
    • Remove the SIM card and tray.
  2. LG G8 ThinQ Front Cameras Replacement, Back Panel: paso 2, imagen 1 de 3 LG G8 ThinQ Front Cameras Replacement, Back Panel: paso 2, imagen 2 de 3 LG G8 ThinQ Front Cameras Replacement, Back Panel: paso 2, imagen 3 de 3
    • Place the phone so that the screen is facing down.
    • Insert opening cards between the back panel and frame of the phone to loosen the clips and adhesive.
    • Using equal pressure, carefully pry the back panel away from the phone.
    • Once enough space has been created, use an opening tool to completely separate the back panel from the phone.
  3. LG G8 ThinQ Front Cameras Replacement, Midframe: paso 3, imagen 1 de 3 LG G8 ThinQ Front Cameras Replacement, Midframe: paso 3, imagen 2 de 3 LG G8 ThinQ Front Cameras Replacement, Midframe: paso 3, imagen 3 de 3
    • Remove all 14 screws from the midframe using a Phillips #000 screwdriver.
    • Work an opening tool around the perimeter of the midframe to pry and remove it from the phone.
  4. LG G8 ThinQ Front Cameras Replacement, Front Cameras: paso 4, imagen 1 de 2 LG G8 ThinQ Front Cameras Replacement, Front Cameras: paso 4, imagen 2 de 2
    • Using an opening tool, carefully disconnect the ribbon cables from both cameras.
  5. LG G8 ThinQ Front Cameras Replacement: paso 5, imagen 1 de 3 LG G8 ThinQ Front Cameras Replacement: paso 5, imagen 2 de 3 LG G8 ThinQ Front Cameras Replacement: paso 5, imagen 3 de 3
    • Using an opening tool, carefully pry up and remove both cameras from the phone casing.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 15
Todo El Tiempo: 559
