Saltar al contenido principal
LG G8 ThinQ Battery Replacement
Qué necesitas
  1. LG G8 ThinQ Battery Replacement, SIM Card Tray: paso 1, imagen 1 de 3 LG G8 ThinQ Battery Replacement, SIM Card Tray: paso 1, imagen 2 de 3 LG G8 ThinQ Battery Replacement, SIM Card Tray: paso 1, imagen 3 de 3
    • Unplug and power off your phone before you begin.
    • Insert the SIM card eject tool into the pinhole in the lower right side of the phone.
    • Remove the SIM card and tray.
  2. LG G8 ThinQ Battery Replacement, Back Panel: paso 2, imagen 1 de 3 LG G8 ThinQ Battery Replacement, Back Panel: paso 2, imagen 2 de 3 LG G8 ThinQ Battery Replacement, Back Panel: paso 2, imagen 3 de 3
    • Place the phone so that the screen is facing down.
    • Insert opening cards between the back panel and frame of the phone to loosen the clips and adhesive.
    • Using equal pressure, carefully pry the back panel away from the phone.
    • Once enough space has been created, use an opening tool to completely separate the back panel from the phone.
  3. LG G8 ThinQ Battery Replacement, Midframe: paso 3, imagen 1 de 3 LG G8 ThinQ Battery Replacement, Midframe: paso 3, imagen 2 de 3 LG G8 ThinQ Battery Replacement, Midframe: paso 3, imagen 3 de 3
    • Remove all 14 screws from the midframe using a Phillips #000 screwdriver.
    • Work an opening tool around the perimeter of the midframe to pry and remove it from the phone.
  4. LG G8 ThinQ Battery Replacement, Speaker System: paso 4, imagen 1 de 3 LG G8 ThinQ Battery Replacement, Speaker System: paso 4, imagen 2 de 3 LG G8 ThinQ Battery Replacement, Speaker System: paso 4, imagen 3 de 3
    • Using an opening tool, carefully pry out remove the speaker system from the phone.
  5. LG G8 ThinQ Battery Replacement, Battery: paso 5, imagen 1 de 1
    • Flip phone so that screen is facing up.
    • Using a heating pad, hairdryer, or heat gun, apply heat to loosen the adhesive beneath the battery.
    • Be careful to not overheat the phone; the screen and battery are susceptible to damage.
    • The adhesive can be difficult to soften; it may take many attempts.
  6. LG G8 ThinQ Battery Replacement: paso 6, imagen 1 de 2 LG G8 ThinQ Battery Replacement: paso 6, imagen 2 de 2
    • Using an opening tool, carefully pry up the ribbon cable to disconnect the battery.
  7. LG G8 ThinQ Battery Replacement: paso 7, imagen 1 de 3 LG G8 ThinQ Battery Replacement: paso 7, imagen 2 de 3 LG G8 ThinQ Battery Replacement: paso 7, imagen 3 de 3
    • Using opening cards or an opening tool, carefully pry around the edges of the battery.
    • If you have trouble prying up the battery, the adhesive may not be loose enough. Re-apply heat, or use some isopropyl alcohol under the battery, allowing it to penetrate for several minutes to weaken the adhesive.
    • Remove the battery from the phone.
Conclusión
6 personas más completaron esta guía.
5Guía Comentarios
You don't use any heat to remove the back glass panel? Just suction cup and prying?
CarnalT - Contestar
Yep need heat to remove the back. Glass shattered on mine. Ifixit needs to fix this guide.
Bryan Ransom - Contestar
Success! I documented the process using ifixit tools on https://waynedavis.com
Wayne Davis - Contestar
thanks for your tutorial man it helped me a lot
John Eric Limbago -
Very helpful tutorials guys. Im in need of replacing my battery in my g8. 2 questions. Do you need to remove the speaker component at the bottom left in order to replace the battery? Some videos i watched they didnt remove it. 2nd question is how to i get the back cover back on after replacing the battery? Is there a specific adhesive i can get?
Johnny XRay - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 9
Ultimos 7 días: 38
Ultimos 30 días: 217
Todo El Tiempo: 10,575
