Saltar al contenido principal
LG G3 Vigor Vibration Motor Replacement
Qué necesitas
  1. LG G3 Vigor Vibration Motor Replacement, Rear Case: paso 1, imagen 1 de 1
    • Locate the notch on the bottom right of the phone.
  2. LG G3 Vigor Vibration Motor Replacement: paso 2, imagen 1 de 1
    • Gently pull the cover on the back of the phone off to locate the battery.
  3. LG G3 Vigor Vibration Motor Replacement, Battery: paso 3, imagen 1 de 1
    • Remove the battery by lifting from the slot at the bottom of the battery.
  4. LG G3 Vigor Vibration Motor Replacement, Midframe: paso 4, imagen 1 de 1
    • Remove the twelve Phillips #00 screws securing the midframe to the rest of the phone.
  5. LG G3 Vigor Vibration Motor Replacement: paso 5, imagen 1 de 3 LG G3 Vigor Vibration Motor Replacement: paso 5, imagen 2 de 3 LG G3 Vigor Vibration Motor Replacement: paso 5, imagen 3 de 3
    • Work a plastic opening tool around the perimeter of the phone to separate the midframe from the rest of the phone.
  6. LG G3 Vigor Vibration Motor Replacement, Rear Facing Camera: paso 6, imagen 1 de 1
    • Use the spudger to gently unplug the ribbon cable connected to the motherboard. Then remove the rear facing camera.
  7. LG G3 Vigor Vibration Motor Replacement, Front Facing Camera: paso 7, imagen 1 de 2 LG G3 Vigor Vibration Motor Replacement, Front Facing Camera: paso 7, imagen 2 de 2
    • Remove the front camera.
  8. LG G3 Vigor Vibration Motor Replacement, Motherboard: paso 8, imagen 1 de 1
    • Use the flat edge of a spudger to disconnect the motherboard ribbon connector.
  9. LG G3 Vigor Vibration Motor Replacement: paso 9, imagen 1 de 2 LG G3 Vigor Vibration Motor Replacement: paso 9, imagen 2 de 2
    • Use the pointed end of a spudger to push back the two motherboard retaining flaps.
    • The motherboard should now be able to be lifted out of the device.
  10. LG G3 Vigor Vibration Motor Replacement, Vibration Motor: paso 10, imagen 1 de 1
    • Use a spudger to remove the vibration motor.
    • It may have some slight adhesive, so some force may be necessary.
Conclusión
Una persona más ha completado esta guía.
Geoff Wacker
Miembro Desde 09/30/13
91,140 Reputación
89 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 457
