Saltar al contenido principal
LG G Watch Spring Bar Pin Replacement
Qué necesitas
  1. LG G Watch Spring Bar Pin Replacement, Wristband: paso 1, imagen 1 de 1
    • Spring bars attach the two halves of the wristband to the watch body. The spring bar has a shoulder on either end.
    • Be prepared to apply some pressure with your fingers to perform the following action.
    • First, slide the wristband down on the spring bar to expose the shoulder of the spring bar.
    • Grasp the exposed shoulder with the tweezers to perform the next step.
  2. LG G Watch Spring Bar Pin Replacement: paso 2, imagen 1 de 2 LG G Watch Spring Bar Pin Replacement: paso 2, imagen 2 de 2
    • This is a challenging step. Do it carefully to prevent the spring bar from flying out of the wristband.
    • Use the tweezer to depress the spring bar so that it collapses by a few millimeters and pops out of the hole that was holding it in place.
    • Now carefully pull the other end of the spring bar to detach the wristband from the watch face.
    • Repeat steps 1 and 2 for the other wristband.
  3. LG G Watch Spring Bar Pin Replacement, Spring Bar Pin: paso 3, imagen 1 de 1
    • Slide the spring bar pin out of the wristband.
    • Repeat this step for the other wristband.
Conclusión
Una persona más ha completado esta guía.
Geoff Wacker
Miembro Desde 09/30/13
88,950 Reputación
89 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 989
