Saltar al contenido principal
LG G Watch R Motherboard Replacement
Qué necesitas
  1. LG G Watch R Motherboard Replacement, Back Case: paso 1, imagen 1 de 2 LG G Watch R Motherboard Replacement, Back Case: paso 1, imagen 2 de 2
    • Power off your watch before disassembling it.
    • Place the watch upside down on a hard surface so that its back case is facing upright.
    • Use a T4 Torx Star screwdriver to remove the four 4.0 mm Torx screws from the corners of the back case.
  2. LG G Watch R Motherboard Replacement: paso 2, imagen 1 de 1
    • Use a plastic opening tool to pry open the back case from both sides of the watch.
  3. LG G Watch R Motherboard Replacement: paso 3, imagen 1 de 1
    • Remove the back case.
  4. LG G Watch R Motherboard Replacement, Motherboard: paso 4, imagen 1 de 2 LG G Watch R Motherboard Replacement, Motherboard: paso 4, imagen 2 de 2
    • With a plastic opening tool, disconnect the four connectors on the top of the motherboard.
  5. LG G Watch R Motherboard Replacement: paso 5, imagen 1 de 2 LG G Watch R Motherboard Replacement: paso 5, imagen 2 de 2
    • Remove three 3.0 mm Phillips screws on the edges of the motherboard with a Phillips #000 screwdriver.
  6. LG G Watch R Motherboard Replacement: paso 6, imagen 1 de 1
    • Grasp the edges of the motherboard and slide it slightly towards the right to remove it from its case.
Conclusión
3 personas más completaron esta guía.
Westley Courchene
Miembro Desde 01/13/15
3,341 Reputación
14 Guías creadas
Equipo
USF Tampa, Team 1-1, Remmell Fall 2015 Miembro de USF Tampa, Team 1-1, Remmell Fall 2015
USFT-REMMELL-F15S1G1
5 Miembros
14 Guías creadas
3 comentarios
Thanks for this! None of the other fixes worked, so I tried this as a last resort with a motherboard borrowed from another G Watch, and it did the trick. So now I know the motherboard was the problem.
H Arumph - Contestar
Where do I buy a replacement motherboard from??
Brandon Reznik - Contestar
Did you ever find anywhere to order a replacement motherboard?
Robert Dye -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 7
Todo El Tiempo: 3,131
