Introducción
The LCD screen of the Konica Minolta Dimage Z6 has been known to cause issues and need replacement. This guide walks through the steps needed to replace a cracked or damaged LCD screen. Please refer to these links for safety precautions when dealing with batteries or broken screens.
Qué necesitas
Push the battery cover in and away from the camera.
Remove all four batteries.
Close the battery cover before continuing.
Carefully use the spudger to pop the LCD screen out of the bracket.
The LCD screen should still be attached by orange ribbon cable and two wires, one orange and one white.
Use tweezers to carefully pull the ribbon cable from the logic board, not from the LCD screen.
Peel back yellow tape on LCD screen to reveal where the two wires are attached. Use tweezers to detach the orange and white wires from the LCD screen.
With the main screen cover in place, follow steps 1-3 in reverse to completely reassemble the device. If the new screen was attached correctly, the camera should function as normal.
