Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Kodak Easyshare C813 Memory Card Replacement
  1. Kodak Easyshare C813 Memory Card Replacement, Memory Card: paso 1, imagen 1 de 1
    • Turn off camera by firmly pressing the power button that is located on the top of the camera near the mode selector dial.
  2. Kodak Easyshare C813 Memory Card Replacement: paso 2, imagen 1 de 3 Kodak Easyshare C813 Memory Card Replacement: paso 2, imagen 2 de 3 Kodak Easyshare C813 Memory Card Replacement: paso 2, imagen 3 de 3
    • Locate battery compartment on bottom of camera and slide open by applying pressure in the direction of the arrow.
  3. Kodak Easyshare C813 Memory Card Replacement: paso 3, imagen 1 de 2 Kodak Easyshare C813 Memory Card Replacement: paso 3, imagen 2 de 2
    • Locate memory card slot and insert memory card by inserting the gold terminals first.
    • Apply pressure into you feel it lock into place.
    • Note: To remove a memory card, apply pressure down until you feel it click. Then it should pop up and you can just pull it up.
  4. Kodak Easyshare C813 Memory Card Replacement: paso 4, imagen 1 de 2 Kodak Easyshare C813 Memory Card Replacement: paso 4, imagen 2 de 2
    • Return the battery door to its formerly closed position.
  5. Kodak Easyshare C813 Memory Card Replacement: paso 5, imagen 1 de 1
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 24-22, Regan Spring 2010 Miembro de Cal Poly, Team 24-22, Regan Spring 2010
CPSU-REGAN-S10S24G22
Miembros de 4
22 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 21
Ultimos 30 días: 76
Todo El Tiempo: 10,647
