Saltar al contenido principal
Kodak EasyShare M530 Control Buttons Replacement
Qué necesitas
  1. Kodak EasyShare M530 Control Buttons Replacement, Control Buttons: paso 1, imagen 1 de 2 Kodak EasyShare M530 Control Buttons Replacement, Control Buttons: paso 1, imagen 2 de 2
    • Front and Back view of camera. Use a Philips Head screw driver to unscrew the sides of the camera. There are six screws total.
  2. Kodak EasyShare M530 Control Buttons Replacement: paso 2, imagen 1 de 2 Kodak EasyShare M530 Control Buttons Replacement: paso 2, imagen 2 de 2
    • Use a Philips Head screw driver to unscrew the sides of the camera. There are two screws on each side except for the top of the camera. Carefully remove face plate of camera. Place alongside near screws.
  3. Kodak EasyShare M530 Control Buttons Replacement: paso 3, imagen 1 de 3 Kodak EasyShare M530 Control Buttons Replacement: paso 3, imagen 2 de 3 Kodak EasyShare M530 Control Buttons Replacement: paso 3, imagen 3 de 3
    • To get to control buttons, use a Phillips Head screw driver to unscrew the three screws near lens.
  4. Kodak EasyShare M530 Control Buttons Replacement: paso 4, imagen 1 de 3 Kodak EasyShare M530 Control Buttons Replacement: paso 4, imagen 2 de 3 Kodak EasyShare M530 Control Buttons Replacement: paso 4, imagen 3 de 3
    • Unscrew the screw near the rechargeable battery compartment. The metal piece then can be removed.
  5. Kodak EasyShare M530 Control Buttons Replacement: paso 5, imagen 1 de 2 Kodak EasyShare M530 Control Buttons Replacement: paso 5, imagen 2 de 2
    • Remove additional screws near lens.
  6. Kodak EasyShare M530 Control Buttons Replacement: paso 6, imagen 1 de 2 Kodak EasyShare M530 Control Buttons Replacement: paso 6, imagen 2 de 2
    • This is what the camera should look like with all screws are removed. Flip camera over to carefully remove the screen cover.
  7. Kodak EasyShare M530 Control Buttons Replacement: paso 7, imagen 1 de 2 Kodak EasyShare M530 Control Buttons Replacement: paso 7, imagen 2 de 2
    • Remove buttons from back case of screen cover. Replace with new set of buttons.
  8. Kodak EasyShare M530 Control Buttons Replacement: paso 8, imagen 1 de 1
    • Follow the steps in reverse order to reassemble the camera. Now you can take beautiful pictures again!
Conclusión
Once you purchase these parts, follow the given instructions. To reassemble your device, follow these instructions in reverse order.
3 personas más completaron esta guía.
Elizabeth
Miembro Desde 01/28/15
291 Reputación
2 Guías creadas
Equipo
Penn State, Team 1-2, Kaschak Winter 2015 Miembro de Penn State, Team 1-2, Kaschak Winter 2015
PSU-KASCHAK-W15S1G2
1 Miembro
4 Guías creadas
1Guía Comentario
como cambio la tapa de la bateria y pin de carga
Dario - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 13
Todo El Tiempo: 784
