Introducción
Is your screen frozen? Check out these troubleshooting steps if you have not already.
If you do in fact want to replace your LED circuit board, then you are in the right place.
It should be noted that this replacement will require you to take apart your entire Kindle, but this guide will help you every step of the way.
Qué necesitas
At each corner, use the blue plastic opening tool to unhook and separate the front panel from the adhesive.
Run the tool along the seams to pry open the front panel.
Herramienta utilizada en este paso:Tweezers$4.99
Flip the screen over to face the motherboard and battery pack.
Use the blunted precision tweezers to gently unclip and detach the cable connecting the battery pack and motherboard.
2 personas más completaron esta guía.
2Guía Comentarios
Where do you buy the replacement parts?
Same here I need a new circuit board ;(
