Saltar al contenido principal
Kicker CXA300.1 Capacitor Replacement
Qué necesitas
  1. Kicker CXA300.1 Capacitor Replacement, Capacitor: paso 1, imagen 1 de 1
    • Remove the five T10 Torx screws from the housing.
  2. Kicker CXA300.1 Capacitor Replacement: paso 2, imagen 1 de 1
    • Remove the two T10 Torx screws from the faceplate.
  3. Kicker CXA300.1 Capacitor Replacement: paso 3, imagen 1 de 2 Kicker CXA300.1 Capacitor Replacement: paso 3, imagen 2 de 2
    • Remove the six T10 Torx screws from the bottom.
    • Pull off the bottom.
  4. Kicker CXA300.1 Capacitor Replacement: paso 4, imagen 1 de 1
    • Desolder the capacitor and remove.
    • Refer to iFixit’s soldering guide to reattach capacitor.
Conclusión
Tim Keptya
Miembro Desde 04/12/18
546 Reputación
4 Guías creadas
Equipo
UW Tacoma, Team S1-G3, Liner Spring 2018 Miembro de UW Tacoma, Team S1-G3, Liner Spring 2018
UWT-LINER-S18S1G3
3 Miembros
4 Guías creadas
Un comentario
Are you out of your mind or was this a late April Fools joke?!? That is NOT how you replace a capacitor, all you did was tear one off the board and take pictures of the carnage.
To replace a through-hole or snap-in capacitor you need to remove the board from the heat sink and (de)solder on the under side. In addition, proper selection of your replacement parts is crucial to the long-term viability of your repair.
If you are replacing a leaky/ruptured capacitor (or in this case, one that’s been torn off the board by a caveman) it’s critical to thoroughly clean any areas of the board and all components that were exposed to the electrolyte. The electrolyte in electrolytic capacitors is corrosive and will destroy the circuit board if it is not removed.
Tim, I encourage a response. Lets get some dialogue going.
Matt - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 5
Ultimos 30 días: 19
Todo El Tiempo: 891
