Saltar al contenido principal
Kenwood DNX571HD CD/DVD Drive Replacement
Qué necesitas
  1. Kenwood DNX571HD CD/DVD Drive Replacement, CD/DVD Drive: paso 1, imagen 1 de 2 Kenwood DNX571HD CD/DVD Drive Replacement, CD/DVD Drive: paso 1, imagen 2 de 2
    • Unscrew the four 3.5mm side screws with a Phillips #1 screwdriver.
    • There are two screws per side.
  2. Kenwood DNX571HD CD/DVD Drive Replacement: paso 2, imagen 1 de 3 Kenwood DNX571HD CD/DVD Drive Replacement: paso 2, imagen 2 de 3 Kenwood DNX571HD CD/DVD Drive Replacement: paso 2, imagen 3 de 3
    • Use a spudger to unhook the plastic clips on the sides and top of the front panel. There are two clips on each side and one clip on the top.
    • Place the spudger between the plastic tab and the metal case and gently lift the spudger away from the case.
  3. Kenwood DNX571HD CD/DVD Drive Replacement: paso 3, imagen 1 de 1
    • Pull the top of the front panel out and down to remove front panel.
    • Remove the front panel gently so as not to damage the ribbon cables behind it.
  4. Kenwood DNX571HD CD/DVD Drive Replacement: paso 4, imagen 1 de 3 Kenwood DNX571HD CD/DVD Drive Replacement: paso 4, imagen 2 de 3 Kenwood DNX571HD CD/DVD Drive Replacement: paso 4, imagen 3 de 3
    • Unscrew the three 5mm screws from the top of the device using a Phillips #1 screwdriver.
    • Lift up to remove the top casing.
  5. Kenwood DNX571HD CD/DVD Drive Replacement: paso 5, imagen 1 de 1
    • Lift the CD drive carefully to expose the attached cable underneath.
  6. Kenwood DNX571HD CD/DVD Drive Replacement: paso 6, imagen 1 de 2 Kenwood DNX571HD CD/DVD Drive Replacement: paso 6, imagen 2 de 2
    • Flip up the black clasp with a spudger to disconnect the large white ribbon cable connecting the CD drive to the board underneath.
Conclusión
Una persona más ha completado esta guía.
Wendy Zaballos
Miembro Desde 09/17/18
952 Reputación
6 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 15
Todo El Tiempo: 1,073
