Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 4 guías que incluyen este paso.
Inglés
Español
Paso 2
Use a spudger to unhook the plastic clips on the sides and top of the front panel. There are two clips on each side and one clip on the top. Place the spudger between the plastic tab and the metal case and gently lift the spudger away from the case. Place the spudger between the plastic tab and the metal case and gently lift the spudger away from the case.
  • Use a spudger to unhook the plastic clips on the sides and top of the front panel. There are two clips on each side and one clip on the top.
  • Place the spudger between the plastic tab and the metal case and gently lift the spudger away from the case.
Insertar traducción aquí
