Saltar al contenido principal
Jumper Angelsounds JPD-100S Volume Knob Replacement
Qué necesitas
  1. Jumper Angelsounds JPD-100S Volume Knob Replacement, Motherboard: paso 1, imagen 1 de 1
    • Access the battery compartment
    • Remove the battery compartment lid and set it aside.
    • Disconnect the battery and set it aside.
  2. Jumper Angelsounds JPD-100S Volume Knob Replacement: paso 2, imagen 1 de 2 Jumper Angelsounds JPD-100S Volume Knob Replacement: paso 2, imagen 2 de 2
    • Puncture the sticker in the battery compartment with a spudger to access the screw beneath it.
  3. Jumper Angelsounds JPD-100S Volume Knob Replacement: paso 3, imagen 1 de 1
    • Remove the 7mm Phillips #1 screw from the battery compartment.
    • Place the screw in a secure place.
  4. Jumper Angelsounds JPD-100S Volume Knob Replacement: paso 4, imagen 1 de 2 Jumper Angelsounds JPD-100S Volume Knob Replacement: paso 4, imagen 2 de 2
    • Begin prying open the device.
    • Insert a plastic opening tool into the side groove about 2cm from the pink plastic component and pry open one side of the device.
    • Once the side is separated, leave the opening tool inside to prevent the two sides from closing.
  5. Jumper Angelsounds JPD-100S Volume Knob Replacement: paso 5, imagen 1 de 2 Jumper Angelsounds JPD-100S Volume Knob Replacement: paso 5, imagen 2 de 2
    • Insert another plastic opening tool into the groove opposite to the side of the tool already inserted.
    • Create separation on that side until the white plastic component comes off entirely.
    • Place the white plastic component in a secure place.
  6. Jumper Angelsounds JPD-100S Volume Knob Replacement: paso 6, imagen 1 de 1
    • With your hand, remove the pink component.
  7. Jumper Angelsounds JPD-100S Volume Knob Replacement: paso 7, imagen 1 de 1
    • Remove the 7mm Phillips #1 screw in the middle of the motherboard.
  8. Jumper Angelsounds JPD-100S Volume Knob Replacement, Volume Knob: paso 8, imagen 1 de 2 Jumper Angelsounds JPD-100S Volume Knob Replacement, Volume Knob: paso 8, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Remove the white glue on the volume knob by peeling it off or gently using tweezers to pull it out.
    • Allow approximately 10 minutes for the soldering station to heat up before using.
  9. Jumper Angelsounds JPD-100S Volume Knob Replacement: paso 9, imagen 1 de 2 Jumper Angelsounds JPD-100S Volume Knob Replacement: paso 9, imagen 2 de 2
    • Remove the 5mm Phillips #00 screw holding the volume knob to the motherboard.
    • Place the screw and volume knob in a secure, safe place.
  10. Jumper Angelsounds JPD-100S Volume Knob Replacement: paso 10, imagen 1 de 3 Jumper Angelsounds JPD-100S Volume Knob Replacement: paso 10, imagen 2 de 3 Jumper Angelsounds JPD-100S Volume Knob Replacement: paso 10, imagen 3 de 3
    • Unsolder the five points holding the volume knob to the motherboard.
    • Carefully place the soldering iron down, as you will need it for reassembly.
Conclusión
Melanie Orozco
Miembro Desde 08/31/15
143 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 6-1, Remmell Fall 2015 Miembro de USF Tampa, Team 6-1, Remmell Fall 2015
USFT-REMMELL-F15S6G1
6 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 189
