Saltar al contenido principal
Jazz UltraTab C855 Battery Replacement
Qué necesitas
  1. Jazz UltraTab C855 Battery Replacement, Back Cover: paso 1, imagen 1 de 1
  2. Jazz UltraTab C855 Battery Replacement: paso 2, imagen 1 de 1
    • Pry the back case off using the blue Plastic Opening Tools. Work one along the seem until you can get your fingers under to pull it apart.
  3. Jazz UltraTab C855 Battery Replacement, Battery: paso 3, imagen 1 de 1
    • Remove the yellow tape from the sides of the battery, and the surrounding components.
  4. Jazz UltraTab C855 Battery Replacement: paso 4, imagen 1 de 1
    • Cut the pos(+) and neg (-) wires that connect the battery to the device using wire cutters.
    • Cut the wires towards the middle. During installation of your new battery these wires will be stripped back and soldered or crimped to reattach.
  5. Jazz UltraTab C855 Battery Replacement: paso 5, imagen 1 de 1
    • Using a plastic opening tool or spudger, slowly pry the battery away from the board.
    • The battery is secured to the device with adhesive.
    • Metal spudgers can puncture an unprotected battery, potentially causing a fire. When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
  6. Jazz UltraTab C855 Battery Replacement: paso 6, imagen 1 de 1
    • Use a two sided adhesive to secure the new battery in place.
    • Solder or crimp the wires back together to reattach to the motherboard.
    • Replace any yellow tape that you removed at the beginning to secure the wires back in place.
Conclusión
Cory Hodge
Miembro Desde 09/14/15
201 Reputación
2 Guías creadas
Equipo
IUPUI, Team 1-3, Baechle Fall 2015 Miembro de IUPUI, Team 1-3, Baechle Fall 2015
IUPUI-BAECHLE-F15S1G3
5 Miembros
10 Guías creadas
Un comentario
Very good instructions.....but where do I buy the repkacement battery from?
fremontmyers - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 565
