Saltar al contenido principal
JBL Flip 3 USB Chip Replacement
Qué necesitas
  1. JBL Flip 3 USB Chip Replacement, USB Chip: paso 1, imagen 1 de 1
    • Remove plastic outer housing using hands or a standard spudger.
    • Important! Note the three alignment pins on the inner part of the housing. When reassembling, take special care to line these up and insert the pins into the receivers on the chassis prior to snapping the edges into place.
  2. JBL Flip 3 USB Chip Replacement: paso 2, imagen 1 de 1
    • Carefully remove outer frame to expose the inner components of the speaker.
  3. JBL Flip 3 USB Chip Replacement: paso 3, imagen 1 de 1
    • loosen the screws to remove the outer frame
  4. JBL Flip 3 USB Chip Replacement: paso 4, imagen 1 de 1
    • Remove the 8 8.9mm Phillips #00 screws to unfasten the side passive drivers. Set the screws and side passive drivers aside safely.
  5. JBL Flip 3 USB Chip Replacement: paso 5, imagen 1 de 1
  6. JBL Flip 3 USB Chip Replacement: paso 6, imagen 1 de 2 JBL Flip 3 USB Chip Replacement: paso 6, imagen 2 de 2
    • Remove the 3 pin connector from the USB chip.
  7. JBL Flip 3 USB Chip Replacement: paso 7, imagen 1 de 1
    • remove screws to expose usb port
Conclusión
49 personas más completaron esta guía.
College Student
Miembro Desde 02/22/17
3,479 Reputación
4 Guías creadas
Equipo
USF Tampa, Team S1-G2, Leahy Spring 2017 Miembro de USF Tampa, Team S1-G2, Leahy Spring 2017
USFT-LEAHY-S17S1G2
5 Miembros
17 Guías creadas
21 comentarios
how can i find the part..email me at leedeen2000@yahoo.com plz
leedeen2000 - Contestar
I feel that the difficulty is just because of the lack of detail on the instructions. I also need to find the part, but where do I get it? I searched on eBay, Amazon and got nothing. That means that I have to scavenge this part from another one?
rodri.mendoza.t - Contestar
i already got step 5, but i need know how i can get the replacement ? Any idea ?
PabloM - Contestar
Looking for the part 2…
Daniel Brockbank - Contestar
Looking for the same thing…
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 79
Ultimos 30 días: 293
Todo El Tiempo: 61,158
