Saltar al contenido principal
Insignia Flex 11.6 Battery Replacement
Qué necesitas
  1. Insignia Flex 11.6 Battery Replacement, Battery: paso 1, imagen 1 de 3 Insignia Flex 11.6 Battery Replacement, Battery: paso 1, imagen 2 de 3 Insignia Flex 11.6 Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Before working on the device, make sure the device is off and not plugged into any power source for safety reasons. Failure to comply could result in injury.
    • Detach the keyboard from the screen in 2 different places by putting one hand on the keyboard while gently pulling up on the screen with the other hand.
  2. Insignia Flex 11.6 Battery Replacement: paso 2, imagen 1 de 2 Insignia Flex 11.6 Battery Replacement: paso 2, imagen 2 de 2
    • Remove the two 6.1 mm Phillips J000 screws from the bottom of the device. Use Phillips Screwdriver size J1.
    • If any screws are stripped, refer to the iFixit guide for how to remove a stripped screw.
  3. Insignia Flex 11.6 Battery Replacement: paso 3, imagen 1 de 3 Insignia Flex 11.6 Battery Replacement: paso 3, imagen 2 de 3 Insignia Flex 11.6 Battery Replacement: paso 3, imagen 3 de 3
    • Using a plastic opening tool, gently pry off the back cover.
  4. Insignia Flex 11.6 Battery Replacement: paso 4, imagen 1 de 3 Insignia Flex 11.6 Battery Replacement: paso 4, imagen 2 de 3 Insignia Flex 11.6 Battery Replacement: paso 4, imagen 3 de 3
    • Remove the electrical connector that connects to the battery to remove the power to the battery.
  5. Insignia Flex 11.6 Battery Replacement: paso 5, imagen 1 de 3 Insignia Flex 11.6 Battery Replacement: paso 5, imagen 2 de 3 Insignia Flex 11.6 Battery Replacement: paso 5, imagen 3 de 3
    Herramienta utilizada en este paso:
    Plastic Cards
    $2.99
    Comprar
    • Make sure not to bend the battery too excessively as if bent too much, it could rupture a cell within the battery and possibly cause a fire.
    • The battery is glued onto the device. To remove it, use a nylon spudger or plastic card to slide underneath the battery and scrape back and forth to remove the glue until the battery is removed from the device.
Conclusión
5 personas más completaron esta guía.
6 comentarios
Donde puedo adquirir la batería?
arag12 - Contestar
There are no screws on the bottom edge of my invicta model P11A8100. Can I bypass removing screws and proceed to removing the back?
Robert Sandfort - Contestar
There are no screws on the bottom of my model P11A8100. Can I bypass removal is said screws and proceed to opening the back?
Great instructions but I cant find a battery replacement. Battery number 3394122-2p
Hank Drabczak - Contestar
Great instructions but now I cant find the battery anywhere it is 3394122-2p
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 32
Todo El Tiempo: 4,623
