Saltar al contenido principal
Insignia Flex 10.1 NS-P16AT10 Screen Replacement
Qué necesitas
  1. Insignia Flex 10.1 NS-P16AT10 Screen Replacement, Screen: paso 1, imagen 1 de 2 Insignia Flex 10.1 NS-P16AT10 Screen Replacement, Screen: paso 1, imagen 2 de 2
    • Make sure your device is off and not connected to any power sources to avoid injury
    • Use a plastic opening tool to remove the rear panel from the front case.
    • Insert the plastic opening tool between the front case and rear panel. Use a prying motion to lift the front case from the rear panel.
    • Work the tool around the perimeter of the device until the front and rear panels become separate.
    • The volume rocker and power button will become free from the device when the front and rear panels are separated from each other. Do not worry. These pieces are easily put back into place when reassembling the tablet.
  2. Insignia Flex 10.1 NS-P16AT10 Screen Replacement: paso 2, imagen 1 de 2 Insignia Flex 10.1 NS-P16AT10 Screen Replacement: paso 2, imagen 2 de 2
    • Use a Phillips head #00 screw driver to remove the thirteen screws.
  3. Insignia Flex 10.1 NS-P16AT10 Screen Replacement: paso 3, imagen 1 de 2 Insignia Flex 10.1 NS-P16AT10 Screen Replacement: paso 3, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Use tweezers to remove the gray pieces located around the speakers and four screws that were removed in the previous step.
    • There should be six grey pieces total.
  4. Insignia Flex 10.1 NS-P16AT10 Screen Replacement: paso 4, imagen 1 de 2 Insignia Flex 10.1 NS-P16AT10 Screen Replacement: paso 4, imagen 2 de 2
    • Use a plastic opening tool to flip up the ribbon cable connector that connects the camera to the motherboard.
  5. Insignia Flex 10.1 NS-P16AT10 Screen Replacement: paso 5, imagen 1 de 1
    • Gently lift the camera lens up from the front case.
  6. Insignia Flex 10.1 NS-P16AT10 Screen Replacement: paso 6, imagen 1 de 2 Insignia Flex 10.1 NS-P16AT10 Screen Replacement: paso 6, imagen 2 de 2
    • Use a plastic opening tool to flip the ribbon connector up in order to free the ribbon cable from the motherboard.
  7. Insignia Flex 10.1 NS-P16AT10 Screen Replacement: paso 7, imagen 1 de 2 Insignia Flex 10.1 NS-P16AT10 Screen Replacement: paso 7, imagen 2 de 2
    • Free the battery from the motherboard by desoldering the red, white, and black connections one by one.
    • For soldering instructions, visit this guide.
    • Remove the soldering tip immediately once the wire has become free. Too much heat can damage the motherboard.
  8. Insignia Flex 10.1 NS-P16AT10 Screen Replacement: paso 8, imagen 1 de 1
    • Peel the black tape up that is attached to the battery and front case.
  9. Insignia Flex 10.1 NS-P16AT10 Screen Replacement: paso 9, imagen 1 de 3 Insignia Flex 10.1 NS-P16AT10 Screen Replacement: paso 9, imagen 2 de 3 Insignia Flex 10.1 NS-P16AT10 Screen Replacement: paso 9, imagen 3 de 3
    • Use a plastic opening tool or spudger to remove the battery from the front case.
    • Place the plastic opening tool between the battery and front case. Work the tool around the perimeter of the battery until the battery is free.
    • Do not bend or puncture the battery, or the battery will leak.
  10. Insignia Flex 10.1 NS-P16AT10 Screen Replacement: paso 10, imagen 1 de 2 Insignia Flex 10.1 NS-P16AT10 Screen Replacement: paso 10, imagen 2 de 2
    • Use tweezers to free the twisted, red and black wire from the three clips on the front case.
  11. Insignia Flex 10.1 NS-P16AT10 Screen Replacement: paso 11, imagen 1 de 3 Insignia Flex 10.1 NS-P16AT10 Screen Replacement: paso 11, imagen 2 de 3 Insignia Flex 10.1 NS-P16AT10 Screen Replacement: paso 11, imagen 3 de 3
    • Remove the speakers from the tablet by gently pulling the yellow tape up from the front case.
  12. Insignia Flex 10.1 NS-P16AT10 Screen Replacement: paso 12, imagen 1 de 2 Insignia Flex 10.1 NS-P16AT10 Screen Replacement: paso 12, imagen 2 de 2
    • Use a plastic opening tool to flip up the ribbon cable connectors that connect the touch digitizer to the motherboard.
  13. Insignia Flex 10.1 NS-P16AT10 Screen Replacement: paso 13, imagen 1 de 3 Insignia Flex 10.1 NS-P16AT10 Screen Replacement: paso 13, imagen 2 de 3 Insignia Flex 10.1 NS-P16AT10 Screen Replacement: paso 13, imagen 3 de 3
    • Gently lift the gray mesh tape up that holds the motherboard down to the front case.
    • Lift the motherboard up from the front case.
    • The speakers are directly connected to the motherboard and will come up with the motherboard.
  14. Insignia Flex 10.1 NS-P16AT10 Screen Replacement: paso 14, imagen 1 de 1
    • Peel away the grey mesh tape that holds down the touch digitizer's ribbon cable to the front case.
  15. Insignia Flex 10.1 NS-P16AT10 Screen Replacement: paso 15, imagen 1 de 2 Insignia Flex 10.1 NS-P16AT10 Screen Replacement: paso 15, imagen 2 de 2
    • Use a plastic opening tool to separate the front case from the LCD screen.
    • Insert the plastic opening tool between the front case and rear LCD screen. Use a prying motion to lift the LCD screen from the front case.
  16. Insignia Flex 10.1 NS-P16AT10 Screen Replacement: paso 16, imagen 1 de 2 Insignia Flex 10.1 NS-P16AT10 Screen Replacement: paso 16, imagen 2 de 2
    • Use a plastic opening tool to flip up the last ribbon cable on the screen.
    • Free the ribbon cable from the LCD screen.
  17. Insignia Flex 10.1 NS-P16AT10 Screen Replacement: paso 17, imagen 1 de 2 Insignia Flex 10.1 NS-P16AT10 Screen Replacement: paso 17, imagen 2 de 2
    • The screen is now free and ready to be replaced.
Conclusión
Morgan Kidd
Miembro Desde 10/10/16
419 Reputación
3 Guías creadas
Equipo
Texas Tech, Team 12-3, Bennett Fall 2016 Miembro de Texas Tech, Team 12-3, Bennett Fall 2016
TTU-BENNETT-F16S12G3
Miembros de 3
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 776
