Introducción
Follow this guide to remove the tank and spout for repair or replacement.
Qué necesitas
Remove the hex head bolt from the top of the access door on the pump head.
Place the spacer collar around the pump rod below the raised chain, with the beveled side down, and the flat side facing up.
Remove the two bolts from the handle side of the pump head.
Use one wrench on the bolt and another on the nut beneath. Hold the bolt stationary and loosen the nut.
Slightly twist the head flange, until the corners overhang the top of the tank far enough to grab.
Screw a T-handle onto the top of the pump rod. Tighten the T-handle up against the jam nut.
