Saltar al contenido principal
India Mark II Access Door Replacement
Qué necesitas
  1. India Mark II Access Door Replacement, Access Door: paso 1, imagen 1 de 2 India Mark II Access Door Replacement, Access Door: paso 1, imagen 2 de 2
    • Before performing any repairs, perform a water test on the pump by raising and lowering the handle a full 40 strokes. A properly performing pump will yield greater than 10 liters.
    • Remove the hex head bolt from the top of the access door on the pump head.
    • On reassembly, this bolt should be hand-tight.
  2. India Mark II Access Door Replacement: paso 2, imagen 1 de 3 India Mark II Access Door Replacement: paso 2, imagen 2 de 3 India Mark II Access Door Replacement: paso 2, imagen 3 de 3
    • Pull the access door straight up off the pump head.
    • Store the access door in a sanitary place to prevent contamination.
  3. India Mark II Access Door Replacement: paso 3, imagen 1 de 2 India Mark II Access Door Replacement: paso 3, imagen 2 de 2
    • The access door has a tongue that fits into the base of the pump head.
    • The access door makes a convenient tray to hold nuts and bolts during the disassembly.
Conclusión
Una persona más ha completado esta guía.
Equipo
iFixit Miembro de iFixit
Staff
140 Miembros
15,221 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 11
Ultimos 30 días: 52
Todo El Tiempo: 1,359
