Introducción
Use this guide to replace the headphone jack in your Huawei P9 Lite.
Qué necesitas
Use an opening pick to unclip the rear cover, starting from the bottom corner.
Work your way around counterclockwise and carefully pry the plastic tabs open one by one.
Remove the nine Phillips #00 screws that secure the metal shield plate.
Disconnect the headphone jack with a spudger.
Take the headphone jack out of its recess.
8 personas más completaron esta guía.
Un comentario
After replacing my audio jack only one side work using headphones
