Saltar al contenido principal
Huawei P8 Lite Camera Replacement
Qué necesitas
  1. Huawei P8 Lite Camera Replacement, Camera: paso 1, imagen 1 de 1
    • Insert the SIM card eject tool into the small circular slots.
    • Apply slight pressure to pop the SIM card out, and remove it.
  2. Huawei P8 Lite Camera Replacement: paso 2, imagen 1 de 1
    • With your finger nails, spudger or other gentle tools, remove the back cover by wedging into the space and popping the edge free.
  3. Huawei P8 Lite Camera Replacement: paso 3, imagen 1 de 1
    • Remove three screws using a Phillips #000 screwdriver.
    • Remove four screws using a T5 Torx screwdriver.
  4. Huawei P8 Lite Camera Replacement: paso 4, imagen 1 de 1
    • Using your fingers, carefully unlatch and remove the connectors attached to the motherboard.
  5. Huawei P8 Lite Camera Replacement: paso 5, imagen 1 de 1
    • With your fingers, gently remove the motherboard and set aside.
  6. Huawei P8 Lite Camera Replacement: paso 6, imagen 1 de 1
    • With the spudger tool, gently lift the front camera from the motherboard.
  7. Huawei P8 Lite Camera Replacement: paso 7, imagen 1 de 2 Huawei P8 Lite Camera Replacement: paso 7, imagen 2 de 2
    • Use the spudger to remove the rear camera.
Conclusión
3 personas más completaron esta guía.
Brayden Mann
Miembro Desde 02/05/16
639 Reputación
4 Guías creadas
Equipo
Metro State, Team 1-2, Carpenter Spring 2016 Miembro de Metro State, Team 1-2, Carpenter Spring 2016
MSU-CARPENTER-S16S1G2
3 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 10
Todo El Tiempo: 1,458
